Select the Self Organizing Map option from the Method list in the Iterative Clustering Control Panel.
Figure 13.8 Self Organizing Map Control PanelĀ
Some of the options on the panel are described in Iterative Clustering Control Panel. The other options are described as follows:
N Rows
The number of rows in the cluster grid.
N Columns
The number of columns in the cluster grid.
Bandwidth
Specifies the effect of neighboring clusters for predicting centroids. A smaller bandwidth results in putting more weight on closer clusters.
