Publication date: 04/28/2021
Show and Hide Items
In the Menu Editor, you show or hide toolbars, buttons, menus, and menu items in specific customization sets. The item’s Source determines where you show or hide the item. For example:
When the Source is All Users, change the customization set to All users to hide the item from all users.
When the Source is JMP Add-In, change the customization set to JMP Add-In followed by the name of the add-in. The item is shown or hidden in all sets that include the selected JMP add-in.
If you do not change the customization set, the item is shown or hidden only in the currently selected set. See Change Customization Sets for more information about customization sets.
Note: To quickly hide or show toolbars for the current user, select or deselect them from the View > Toolbars list.
To show and hide items in a customization set, follow these steps:
1. Select View > Customize > Menus and Toolbars.
The Menu Editor appears.
2. Select the customization set that you want to modify.
3. Select the item that you want to show or hide.
4. Select or deselect Hidden in the General properties. See Step 2: Specify the Caption and Internal Name for more information about the General properties.
5. Click Save to save your changes.
