Multivariate Methods > Structural Equation Models > Structural Equation Models Platform Options
Publication date: 04/28/2021
The Structural Equation Models red triangle menu contains the following options:
Path Diagram
Contains the following options to modify the path diagram display:
Color Path Diagram
Colors the variables in the path diagram.
Show Variances
Shows or hides the bidirectional arrows that represent variances in the path diagram.
Show Latent Indicators
Shows or hides the latent variable indicators in the path diagram.
Layout
Contains six options for different arrangements of the items in the path diagram. These six options correspond to the same arrangements that you can cycle through using the Change Diagram Layout button in the Diagram panel. You can also drag items in the path diagram to change the arrangement of specific items.
Descriptive Statistics
Contains the following options to produce descriptive statistics:
Univariate Simple Statistics
Shows or hides a univariate simple statistics report. The statistics in this report are estimated for each column independently from other columns that might have missing data.
Full Information Multivariate Statistics
Shows or hides a multivariate simple statistics report. The statistics in this report are estimated with full information maximum likelihood to account for missing data.
Launch Explore Outliers
Launches the Explore Outliers platform. See Modeling Utilities in Predictive and Specialized Modeling.
Launch Explore Missing Values
(Not available when there are no missing values.) Launches the Explore Missing Values platform. See Modeling Utilities in Predictive and Specialized Modeling.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
