JMP provides descriptive tooltips (or hover labels) when you place your cursor over items, such as the following:
• Menu or toolbar options
• Labels in graphs
• Text results in the report window (move your cursor in a circle to reveal)
• Files or windows in the Home Window
• Code in the Script Editor
Tip: On Windows, you can hide tooltips in the JMP Preferences. Select File > Preferences > General and then deselect Show menu tips. This option is not available on macOS.
