Using JMP > Get Started > JMP Home Window on Windows > Using the Reveal Feature
Publication date: 04/28/2021
On Windows, press F9 to use the Reveal feature. The Reveal feature shows a top-level window with thumbnails of all open JMP windows.
Click a window to activate it.
Press the spacebar to turn on Preview mode, where a full-sized view of the thumbnail under the cursor appears in the center of the screen.
By default, the windows are ordered to match the original ordering on the screen in a top-down, left-to-right order. Press S to sort the thumbnails by name.
To exit the Reveal feature, press F9, Esc, or Alt and Tab and then select another application.
