Design of Experiments Guide > Augment Designs
Publication date: 04/30/2021
Augment Designs
Use the Augment Design platform to add runs to an existing experimental design. Experimentation is often a sequential process and augmenting a designed experiment can help resolve ambiguities that result from a single design.
For an existing design table, the Augment Design platform constructs additional runs that optimize the overall design. You can add runs to accomplish the following objectives:
Replicate the design a specified number of times.
Add center points.
Create a foldover design.
Add axial points together with center points to transform a screening design to a response surface design.
Add space filling points to a design.
Add runs to the design in order to fit a specific model.
For more information about augmenting designs see Goos and Jones (2011).
Figure 6.1 Original Design Runs (+) with Augmented Runs (o)
Contents
Example Using the Augment Design Platform
Analyze the Augmented Design
Launch the Augment Design Platform
Augment Design Window
Factors
Define Factor Constraints
Augmentation Choices
Augment Design Platform Options
Additional Examples of Augmentation Choices
Replicate a Design
Add Center Points to a Design
Create a Foldover Design
Add Axial Points to a Design
Space Filling Augmentation
Statistical Details
