Essential Graphing > Contour Plots
Publication date: 04/30/2021
Contour Plots
View Multidimensional Relationships in Two Dimensions
The Contour Plot command in the Graph menu constructs contours of a response in a rectangular coordinate system. A contour plot shows a three-dimensional surface in two dimensions. Contours delineate changes in the third dimension.
Here are some of the options available with the Contour platform:
specify the number of contour levels
choose to plot contour lines or filled contours
show or hide data points
label contours with response values
define and use a custom coloring scheme
Figure 10.1 Examples of Contour Plots
Contents
Example of a Contour Plot
Example Using the Contour Platform
Example of a Contour Plot in Graph Builder
Launch the Contour Plot Platform
The Contour Plot
Contour Plot Platform Options
Fill Areas
Contour Specification
Contour Plot Save Options
Use Formulas for Specifying Contours
Additional Example of Contour Plots
