Design of Experiments Guide > The Fit Group Orthogonal Supersaturated Platform > Fit Group Orthogonal Supersaturated Platform Options
Publication date: 04/30/2021
The red triangle menu in the Fit Group Orthogonal Supersaturated Design platform contains the following options:
See Redo Menus and Save Script Menus in Using JMP for more information about the following options:
Redo
Save Script
Statistical Details for the Fit Group Orthogonal Supersaturated Platform
A two-stage strategy is used to fit group orthogonal supersaturated designs. The first stage identifies which groups contain active effects.
Obtain an estimate of σ from the fake factors and then discard the fake factors from further analyses.
Test for significance of each group of factors.
The second stage considers significance of individual factors in active groups. This stage uses a guided subsets procedure. See Jones and Nachtsheim (2016). For complete statistical details, see Jones, et al. (2019).
