Using JMP > Import Your Data
Publication date: 04/30/2021
Import Your Data
Create Data Tables
This chapter covers the following topics:
How to import data into JMP, such as text files, PDF files, SPSS files, and SAS data
How to transfer Excel data into a JMP data table
How to read in real-time data
How to create a new data table
Figure 3.1 Importing a Text File
Contents
About Importing Data to JMP
Import Microsoft Excel Files
Preview and Import the Microsoft Excel Data
Import a Microsoft Excel File Directly
Import Text Files
Text Import Wizard Options
Open a Text File in a Text Editing Window
Import Text from the Script Editor
Import Multiple Files
Import PDF Files
Concatenate Tables into One Data Table
Concatenate Tables by Column Headers
Import Tables that are Not Auto-Detected
PDF Preview Red Triangle Options
Data Table Preview Options
PDF Preview Right-Click Options
Import XML and JSON Files
Preview and Import the XML or JSON Data
Import XML Files Directly
Import JSON Files Directly
Build SQL Queries in Query Builder
Connect to a SQL Database
Select Tables from a SQL Database
Build the SQL Query
Save and Run the Query
Open the Selected Data in JMP
Options
Write SQL Statements in Query Builder
Import Data from SAS
Java Runtime Environment (JRE) Requirements
SAS Menu Options
Import SAS Data Sets
Create SAS Transport Files in SAS
Connect to SAS
Open SAS Data Sets with SAS Query Builder
Open SAS Data Sets through a SAS Server
Using SAS Extended Attributes to Import Metadata
Run Stored Processes
Submit SAS Code
Generate ODS Results
Retrieve Generated SAS Data Sets
Import Data from a Database
Connect to a Database
Open Data from a Database
Write SQL Statements to Query a Database
Structured Query Language (SQL): A Reference
Import Data from Google Sheets
About Importing Google Sheets
Google Sheet Settings
Import SPSS Files
Import Triple-S Survey Data
Import HDF5 Data
Import Data from MATLAB
Import Data from R
Import Data Using the Excel Add-In
Transfer Excel Data to a JMP Data Table
About the JMP Add-In for Excel
Uninstall the Excel Add-In
Import Data from the Internet or a Remote Computer
Create New Data Tables
