Using JMP > JMP Preferences > Mac OS Settings
Publication date: 04/30/2021
Mac OS Settings
Mac OS Settings preferences customize settings for macOS machines, including the graphics formats and file associations.
Figure 13.12 Mac OS Settings Preferences
Table 13.12 Preferences on the Mac OS Settings Page
Preference
Description
Alternate Image Formats for Clipboard and Drag & Drop
Select one or more graphic formats to use when copying and pasting (or dragging and dropping) graphics from JMP into other applications.
Clipboard Image Scale Factor
Enter the percentage at which you want graphics to appear in other applications.
Image format for RTF
Select the format to use for graphics when you save a JMP report as an RTF file.
RTF Image Scale Factor
Enter the percentage at which you want graphics to appear in RTF documents.
Image format for HTML
Select the format to use for graphics when you save a JMP report as an HTML file.
