Predictive and Specialized Modeling > Bootstrap Forest > The Bootstrap Forest Report
Publication date: 04/30/2021
After you click OK in the Bootstrap Forest Specification window, a window appears that informs you of approximately how long it will take JMP to fit the model. If the approximated time is too long, you have the option to view the current model by selecting Accept Current Model. The Bootstrap Forest report appears after the complete model is fit or after the current model is accepted.
Figure 5.9 Accept Current Model Dialog
Figure 5.10 Bootstrap Forest Report for a Categorical Response
Figure 5.11 Bootstrap Forest Report for a Continuous Response
The following reports are provided, depending on whether the response is categorical or continuous:
Model Validation-Set Summaries
Specifications
Overall Statistics
Cumulative Validation
Per-Tree Summaries
