• Example of an Analysis of Means Chart
• Example of an Analysis of Means for Variances Chart
• Example of the Each Pair, Student’s t Test
• Example of the All Pairs, Tukey HSD Test
• Example of the With Best, Hsu MCB Test
• Example of the With Control, Dunnett’s Test
• Example of the Each Pair Stepwise, Newman-Keuls Test
• Example Contrasting Four Compare Means Tests
• Example of the Nonparametric Wilcoxon Test
• Example of the Unequal Variances Option
• Example of an Equivalence Test
• Example of the Robust Fit Option
• Example of a Normal Quantile Plot
• Example of the Densities Options
