Each Analysis of Means Methods option adds an Analysis of Means red triangle menu to the report window.
Set Alpha Level
Select an option from the most common alpha levels or specify any level with the Other selection. Changing the alpha level modifies the upper and lower decision limits.
Note: For ANOM for Ranges, only the selections 0.10, 0.05, and 0.01 are available.
Show Summary Report
The reports are based on the Analysis of Means method:
– For ANOM, creates a report showing group means and decision limits.
– For ANOM with Transformed Ranks, creates a report showing group mean transformed ranks and decision limits.
– For ANOM for Variances, creates a report showing group standard deviations (or variances) and decision limits.
– For ANOM for Variances with Levene (ADM), creates a report showing group mean ADMs and decision limits.
– For ANOM for Ranges, creates a report showing group ranges and decision limits.
Graph in Variance Scale
(Available only for ANOM for Variances.) Changes the scale of the vertical axis from standard deviations to variances.
Display Options
Contains the following options to customize the display:
Show Decision Limits
Shows or hides decision limit lines.
Show Decision Limit Shading
Shows or hides decision limit shading.
Show Center Line
Shows or hides the center line statistic.
Point Options: Show Needles
Shows the needles. This is the default option. Show Connected Points shows a line connecting the means for each group. Show Only Points shows only the points representing the means for each group.
