The Attribute Gauge red triangle menu contains the following options:
Attribute Gauge Charts
Shows or hides the gauge attribute chart and the efficiency chart.
Show Agreement Points
Shows or hides the agreement points on the charts.
Connect Agreement Points
Connects the agreement points in the charts.
Agreement by Rater Confid Intervals
Shows or hides the agreement by rater confidence intervals on the efficiency chart.
Show Agreement Group Means
Shows or hides the agreement group means on the gauge attribute chart. This option is available when you specify more than one X, Grouping variable.
Show Agreement Grand Mean
Shows or hides the overall agreement mean on the gauge attribute chart.
Show Effectiveness Points
Shows or hides the effectiveness points on the charts.
Connect Effectiveness Points
Draws lines between the effectiveness points in the charts.
Effectiveness by Rater Confid Intervals
Shows or hides confidence intervals on the second chart in the Attribute Gauge Chart report (Figure 6.5).
Effectiveness Report
Shows or hides the Effectiveness report. This report compares every rater with the standard, using the Kappa statistic.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
