Publication date: 09/28/2021
Autocomplete Functions
If you do not remember the exact name of a function, use autocompletion to see a list of functions that match what you have typed so far. Type part of the name, and then press Ctrl+Space on Windows (Option+Esc on macOS).
Suppose that you want to clear your JSL variables, but do not remember the command. You can type clear and then press Ctrl+Space, to see a list of possible clear commands. Select the command that you want to insert.
Figure 4.3 Autocomplete Example
