The following messages for a hierarchical cluster object are available only in JSL:
// returns the column names in cluster order (for two-way clustering)
hier_cluster_object << Get Column Names
// returns a vector of cluster numbers
hier_cluster_object << Get Clusters
/* returns a vector of the display position for each row in the cluster,
with missing values for undisplayed rows */
hier_cluster_object << GetDisplayOrder
/* returns a vector of the display position for each column
(for two-way clustering)*/
hier_cluster_object << GetColumnDisplayOrder
// returns the distance matrix used for hierarchical clustering
hier_cluster_object << Get Distance Matrix
The following message for a KMeans cluster object is available only in JSL. The message returns the mean and standard deviation for each variable within each cluster.
kmeans_cluster_object << Get Statistics
