Publication date: 09/28/2021
Control Limits for XBar and R Charts
JMP generates control limits for XBar and R charts using the following formulas:
LCL for XBar chart = Equation shown here
UCL for XBar chart = Equation shown here
LCL for R chart = Equation shown here
UCL for R chart = Equation shown here
Center line for R chart: By default, the center line for the ith subgroup (where K is the sigma multiplier) indicates an estimate of the expected value of Ri. This value is computed as follows: Equation shown here, where Equation shown here is an estimate of σ.
The standard deviation for XBar and R charts is estimated using the following formula:
Equation shown here
where:
Equation shown here = weighted average of subgroup means
K = the sigma multiplier and is set to 3 by default
σ = process standard deviation
ni = sample size of ith subgroup
d2(n) is the expected value of the range of n independent normally distributed variables with unit standard deviation
d3(n) is the standard deviation of the range of n independent normally distributed variables with unit standard deviation
Ri is the range of ith subgroup
N is the number of subgroups for which ni ≥ 2.
