Use the options in the Correspondence Analysis red triangle menu to add a 3-D scatterplot to the Contingency report and to add column properties to the data table.
3D Correspondence Analysis
Produces a 3-D scatterplot.
Save Value Order
Takes the order of the levels sorted by the first correspondence score coefficient and makes a column property for both the X and Y columns.
