Show Letters
Shows or hides the column letter IDs in the Crosstab table. These letters are used in many of the tests of homogeneity and are displayed automatically for those tests.
Specify Comparison Groups
Enables you to specify specific comparison groups for tests of homogeneity. Use group comparison letters separated by a slash to represent each group. Separate multiple groups by commas. For example, to test A with E, B with D, and C with F, specify the groups as “A/E, B/D, C/F”. A Compare Each Cell report is provided for the defined comparison groups. See Example of User-Specified Comparison with Comparison Letters.
Remove
Removes the report from the report window.
Caution: The Remove option cannot be undone.
