Factor Settings
Contains options identical to the Factor Settings submenu in the Prediction Profiler. See Factor Settings.
Log Iterations
Creates a data table that contains iterations of the optimization algorithm. The data table appears after the Optimize button is clicked.
Alter Linear Constraints
Enables you to add, change, or delete linear constraints. The constraints are used in the Custom Profiler. See Linear Constraints.
Save Linear Constraints
Saves existing linear constraints as a data table script that is named Constraint. See Linear Constraints.
Simulator
Launches the Simulator. See Simulator.
