When you hover over a visual element in a graph, usually you see a basic description of the data point in a hover label. Customize what appears in the hover label in any of these ways:
Add interactive graphs or images using graphlets. |
Add formatted text using textlets. |
Add, remove, or update names and values using gridlets. |
Learn more about using the Hover Label Editor. |
Add images from data tables. |
Pin hover labels on graphs. |
Format hover labels and access additional options. |
Figure 9.40 Examples of Graphs, Text, Names, and Values in Hover LabelsĀ
