The Dependent Variables red triangle menu provides the following options:
Formula
Shows or hides the Formula column in the Dependent Variables controls.
Surface
Shows or hides the Surface column in the Dependent Variables controls.
Points
Shows or hides the Point Response Column column in the Dependent Variables controls.
Response Grid
Shows or hides the Grid controls.
