ADI Loading Matrix
(Available only for the ADI utility.) Shows or hides a report that contains the columns that correspond to the factor loading for each component.
See Redo Menus in Reports and Save Script Menus in Reports in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
