Publication date: 09/28/2021
Fit Cauchy
The Cauchy option estimates parameters using maximum likelihood and a Cauchy link function. This method assumes that the errors have a Cauchy distribution. A Cauchy distribution has fatter tails than the normal distribution, resulting in a reduced emphasis on outliers. This option can be useful if you have a large proportion of outliers in your data. However, if your data are close to normal with only a few outliers, this option can lead to incorrect inferences.
