Publication date: 09/28/2021
Fit Parametric Survival Script-Only Messages
The following JSL messages return the requested item from the fitted model, such as parameter names, parameter estimates, standard error, and so on:
survival_object << Get Parameter Names
survival_object << Get Estimates
survival_object << Get Std Errors
survival_object << Get Effect Names
survival_object << Get Effect PValues
