You can select the same fitting option multiple times, and each new fit is overlaid on the scatterplot. You can try fits, exclude points and refit, and you can compare them on the same scatterplot.
To apply a fitting option to multiple analyses in your report window, hold down the Ctrl key and select a fitting option.
