Fitting option categories include regression fits and density estimation.
Category |
Description |
Fitting Options |
Regression Fits |
Regression methods fit a curve to the observed data points. The fitting methods include least squares fits as well as spline fits, kernel smoothing, orthogonal fits, and robust fits. |
Fit Mean Fit Line Fit Polynomial Fit Special Flexible Fit Orthogonal Robust |
Density Estimation |
Density estimation fits a bivariate distribution to the points. You can either select a bivariate normal density, characterized by elliptical contours, or a general nonparametric density. |
Density Ellipse Nonpar Density |
