You can use the following commands inside Graph Box() statements. This chapter focuses on the JSL that is specific to graphing, but you can also use general script commands such as For and While.
Note: New Window() expects window and display box commands, and platforms expect platform commands. Therefore, the general script commands such as For and While might not work inside platforms or New Window(), or you might get unexpected results.
