Publication date: 09/28/2021
Graph Options
Right-clicking in a graph shows the following:
1. Element types that appear in the plot (such as Points, Line, and so on). Sub-menus provide options that are specific to each element type, and general options. Alternatively, you can change element-specific options in each element’s properties panel, below the Variables panel.
2. The Add option, where you can select other elements to add to the graph. Alternatively, you can add more elements to the graph by dragging the desired element icons.
3. The Rows, Graph, Customize, and Edit menus. For descriptions of these options, see Using JMP.
Tip: Select Rows > Name Selection in Column to create a new column to name and label selected points in a graph.
