Right-clicking in the X Group, Y Group, Wrap, Color, Size, and Overlay zones can show the following options:
Levels in View
Changes the number of levels of the grouping variable that are visible. Use the arrow buttons to scroll forward and backward.
Number of Levels
Changes the number of levels. See Categorical and Continuous Variables in Group X or Y Zones.
Order By
Orders the levels of a variable. See Order the Levels of a Categorical Variable.
Show Title
Shows or hides the variable title.
Title Orientation
Changes the orientation of the variable text to horizontal or vertical.
Level Orientation
Changes the orientation of the level values to horizontal or vertical.
Levels per Row
Changes the number of columns included in the graph. Use with a Wrap variable.
Color
Changes the background color of the grouping zone.
X or Y Group Edge
Moves the grouping variable labels. See Move Group X and Group Y Labels.
Summary Statistic
Applies color and or size variables based on a summary statistic. Available only for a summarized Y response.
Swap
Swaps the position of two variables. See Move or Remove Variables in Zones.
Remove
Removes a variable.
