The PDF Import Wizard enables you to preview a PDF file, adjust the import settings, and view the results in the data table preview before you import the data. JMP attempts to auto-detect the data structure in the PDF file, or you can customize the structure.
Note: A PDF file consists of tables that contain data. In the PDF preview, the tables are outlined and selected on each page.
• Concatenate Tables into One Data Table
• Concatenate Tables by Column Headers
• Import Tables that JMP Does Not Auto-Detect
