Inquiry functions identify the type of an element, such as a string, list, or matrix. You can then write a script specific to that element type.
JMP also uses inquiry functions to determine the writability of a directory or file and to identify a computer’s operating system and the JMP version.
The Type() function returns a string naming the type of the resulting value. For example:
Show( Type( 1 ), Type( "hi" ), Type( {"a", 2} ), Type( [10 24 325] ) );
results in:
Type(1) = "Integer"
Type("hi") = "String"
Type({"a", 2}) = "List"
Type([10 24 325]) = "Matrix";
