When you click OK in the launch window, the Iterative Clustering report window appears, showing a Control Panel for fitting models. See Iterative Clustering Control Panel. As you fit models, additional reports are added to the window. See K Means Report.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
