JMP App Module
A JMP application module is a definition of the display box layout and behavior for a single component in a JMP application or dashboard. Depending on the module type, the component might represent a window in the application or just part of a window.
module<<Create Instance
Use Create Instance within a JMP App() or JMP App Module() script to create an instance of a JMP app module. By default, one instance of each JMP application module is created when an application is run. For more complex applications with multiple windows, such as a launcher and report combination, it might be necessary to change the default settings and control how the module instance is created.
module<<Get Instance
Returns a handle to the application that owns a module.
