JMP preferences enable you to specify general and specific settings and save the settings.
To change preferences
1. Select File > Preferences (Windows) or JMP > Preferences (macOS). The window in Figure 13.1 appears. The previous preferences page that you selected appears.
2. Click a category and make selections. Click Apply to see the results, and then click OK.
Note: When you upgrade to JMP 16 Subscription, changes to preferences are maintained. In other JMP versions, you must customize the preferences after each upgrade.
To search preferences
2. In the Filter box at the top, enter your text.
Text matches are highlighted.
3. Under Preference Group, click a category to see its results.
A search term can show up in these places:
• the preference itself
• a tooltip for the preference
• a list of options for a preference
To reset preferences to the default settings
2. Click Reset All, and then click OK.
