Publication date: 09/28/2021
K-Fold and Holdback Validation
The Validation Column role provides a framework for partitioning data into cross validation sets. In addition, some JMP platforms also support K-Fold and various types of Holdback validation.
K-Fold Cross-Validation
Divides the original data into K subsets. In turn, each of the K sets is used to validate the model fit on the rest of the data, fitting a total of K models. The model that produces the best validation statistic is chosen as the final model, and the fold that is not used in the building of that model provides the test set performance statistics.
Note: For some platforms, you must specify K-Fold Cross-Validation in the model control panel. For other platforms, you must specify K-Fold Cross-Validation in the platform launch window. For still other platforms, you must specify K-Fold Cross-Validation through a validation column that contains more than three levels.
Random Validation Holdback
(Available as a launch option for specific platforms.) Randomly divides the original data into the training and validation sets. A test set can also be included. You can specify the proportions of the original data to use in each set.
Leave-One-Out Validation Holdback
(Available as an option for specific platforms.) Repeatedly fits the model leaving out one observation at a time. Leave-one-out validation is also known as the jackknife procedure.
Excluded Rows as Validation Holdback
Uses the excluded rows in the data table as a validation holdback set. For JMP Pro, this option is available by selecting in the platform preferences.
Note: For platforms that support using excluded rows as a validation holdback set, the excluded rows are used only when there is no validation column or validation proportion specified in the launch window.
Table A.2 K-Fold and Holdback Validation by Platform
Platform
Leave-One-Out Holdback
Fit Model
Fit Least Squares
No
No
No
No
Stepwise Regression
No
No
No
Yes (for continuous response models only)
Logistic Regression
No
No
No
No
Image shown hereGeneralized Regression
No
Yes
Yes
Yes (though the model controls)
Image shown herePartial Least Squares
No
Yes
Yes
Yes (through the model controls)
Predictive Model
Neural
Yes
Yes
No
Yes (through model launch or validation column)
Partition
Yes
Yes
No
Yes (select the option in the platform preferences)
Image shown hereBootstrap Forest
Yes
Yes
No
No
Image shown hereBoosted Tree
Yes
Yes
No
No
Image shown hereK Nearest Neighbors
Yes
Yes
No
No
Image shown hereNaive Bayes
Yes
Yes
No
No
Image shown hereSupport Vector Machines
No
Yes
No
Yes (through model launch)
Specialized Models
Image shown hereFunctional Data Explorer
No
No
No
No
Multivariate Models
Discriminant
Optional
No
No
No
No
Yes
Yes
Image shown hereUplift
No
Yes
No
