Each K Means report gives the following summary statistics for each cluster:
• The Cluster Summary report gives the number of clusters and the observations in each cluster, as well as the number of iterations required.
• The Cluster Means report gives means for the observations in each cluster for each variable.
• The Cluster Standard Deviations report gives standard deviations for the observations in each cluster for each variable.
