The following legacy platforms are deprecated. A deprecated platform is an older platform that contains features that can be accessed in a newer platform. The charts and plots in this appendix are all available in the Graph Builder platform. These legacy platforms might not be available in future releases of JMP.
Platform |
Graph Builder References |
Treemap |
• Treemap |
Chart |
• Bar chart examples in Graph Builder Examples |
Overlay Plot |
Treemaps are useful for observing patterns among groups that have many levels. Use treemaps when your data contains many categories, to visualize many groups.
Tip: To create a treemap, consider using Graph Builder. See Treemap.
Launch the Treemap platform by selecting Graph > Legacy > Treemap.
When you click OK in the launch window, a treemap in Graph Builder is created by default. To produce a report in the legacy Treemap platform, you must first deselect the Use Graph Builder platform preference under Files > Preferences > Platforms > Treemap. Documentation for the legacy Treemap platform launch window, report, and options can be found here: https://www.jmp.com/support/help/en/15.2/#page/jmp/legacy-platforms.shtml.
The Chart platform on the Graph menu charts continuous variables versus categorical variables. The continuous variables are summarized for each categorical level.
If you want to make a plot of individual data points (rather than summaries of data points), we recommend using an overlay plot instead.
Tip: To create a chart, consider using Graph Builder. See Example of an Overlaid Histogram and Ridgeline Chart.
Launch the Chart platform by selecting Graph > Legacy > Chart.
When you click OK in the launch window, a chart in Graph Builder is created by default. To produce a report in the legacy Chart platform, you must first deselect the Use Graph Builder platform preference under Files > Preferences > Platforms > Chart. Documentation for the legacy Chart platform launch window, report, and options can be found here: https://www.jmp.com/support/help/en/15.2/#page/jmp/legacy-platforms.shtml.
The Overlay Plot option produces plots of a single X column and one or more numeric Ys and does not accept non-numeric values for the y-axis.
Tip: To create an overlay plot, consider using the Overlay zone in Graph Builder. See Example of an Overlaid Histogram and Ridgeline Chart.
Launch Overlay Plot by selecting Graph > Legacy > Overlay Plot.
When you click OK in the launch window, an overlay plot in Graph Builder is created by default. To produce a report in the legacy Overlay Plot platform, you must first deselect the Use Graph Builder platform preference under Files > Preferences > Platforms > Overlay Plot. Documentation for the legacy Overlay Plot platform launch window, report, and options can be found here: https://www.jmp.com/support/help/en/15.2/#page/jmp/legacy-platforms.shtml.
