Publication date: 09/28/2021
Manage Spec Limits Options
In the window where you set specification limits, there are buttons to save and load specification limits, and options in the Manage Spec Limits red triangle menu.
Report Table Columns
The table at the top of the Manage Spec Limits report contains a row for each process column specified in the launch window. This table enables you to specify specification limits as well as the following options for each column:
Show Limits
Specifies that the Show as Graph Reference Lines option is selected in the Spec Limits column property for the specified column.
Process Importance
Specifies the process importance value for each column. Process importance values provide a mechanism to sort processes in the order that you prefer. Process importance values are used to size markers in many platform graphs.
Units
Specifies the units for each column.
Buttons
Load from Limits Table
Loads specification limits from a JMP data table.
Save to Column Properties
Saves the specification limits as column properties in the associated data table.
Save to Tall Spec Limits Table
Saves the specification limits to a new data table in tall format.
Save to Wide Spec Limits Table
Saves the specification limits to a new data table in wide format.
Red Triangle Options
Show Limits All
Selects boxes under Show Limits for all of the columns. If Show Limits is selected for a column, the Show as Graph Reference Lines option is selected in the Spec Limits column property. The Show as Graph Reference Lines option displays the specification limits and target that you specify as reference lines in select analysis plots.
Note: If all boxes under Show Limits are selected, the Show Limits All option deselects all of the boxes under Show Limits.
Round Decimals
Sets the number of decimal places to which you want the specification limits rounded.
Color Out of Spec Values
Colors any values in the data table that are outside the specification limits for the columns.
See Redo Menus in Reports and Save Script Menus in Reports in Using JMP for more information about the following options:
Redo
Save Script
