Quality and Process Methods > Model Driven Multivariate Control Charts > Model Driven Multivariate Control Chart Platform Options
Publication date: 09/28/2021
Show History Summary Statistics
Shows or hides summary statistics for rows designated as historical data or all rows if historical data rows are not specified. Summary statistics include univariate means and standard deviations for process variables. For PCA-based charts, the eigenvalues and eigenvectors are displayed. For charts based on PLS scores, the standard deviation of scores and the score loadings are displayed.
Monitor the Process
Show Monitoring Plots
Shows or hides the selected process monitoring plots.
Set Component
Enables you to set the number of components for the T2, DModX, or SPE plots. The number of components can range from one up to the number of valid eigenvectors for PCA driven analysis or from one up to the number of PLS model factors for PLS driven analysis.
Set α Level
Enables you to adjust the alpha level that is used for all control chart limits.
T2 Plot
Shows or hides a T2 plot. The T2 statistic is a summary of multivariate variation that measures how far away an observation is from the center of a PCA or PLS model.
Normalized DModX Plot
Shows or hides a plot of the normalized DModX values. DModX measures the distance of each observation to the PCA or PLS model. A high DModX value indicates an observation that deviates from the underlying correlation structure of the data.
Squared Prediction Error Plot
Shows or hides the squared prediction error (SPE) plot. SPE measures the sum of squared of the residuals from the PCA or PLS model. A high SPE value indicates an observation that deviates from the underlying correlation structure of the data.
Score Plot
Shows or hides a score plot of principal components or partial least squares factors. See Score Plot.
Diagnose the Process
(Available when at least one diagnostic plot is active.) Shows or hides diagnostic plots.
See Redo Menus in Reports and Save Script Menus in Reports in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
