When you click Go in the Control Panel, the following reports appear:
• A Cluster Comparison report. See Cluster Comparison Report
• One or more Normal Mixtures reports. The reports are dynamically named Normal Mixtures NCluster=<k>, depending on k, the number of clusters fit. A Normal Mixtures NCluster=<k> report appears for each fit that you conduct.
The Cluster Comparison report and the Normal Mixtures NCluster=6 report for the Cytometry.jmp data table, with the variables CD3 through MCB as Y, Columns, are shown in Figure 14.2 and Normal Mixtures NCluster=6 Report.
