You can create two types of normal quantile plots:
• Plot Actual by Quantile creates a plot of the response values versus the normal quantile values. The quantiles are computed and plotted separately for each level of the X variable.
• Plot Quantile by Actual creates a plot of the normal quantile values versus the response values. The quantiles are computed and plotted separately for each level of the X variable.
The Line of Fit option shows or hides the lines of fit on the quantile plots. The Normal Quantile Label option shows or hides labels inside the right vertical axis of the Normal Quantile Plot and inside the top axis of the Actual by Quantile plot. The labels represent the normal quantile scale.
The Normal Quantile Plot options are not available when a Block variable is specified in the launch window.
