The red triangle menus next to each variable in the report window contain additional options that apply to the variable. This section describes the options that are available for continuous variables.
Display Options
See Display Options for Continuous Variables.
Histogram Options
See Histogram Options for Continuous Variables.
Normal Quantile Plot
Helps you visualize the extent to which the variable is normally distributed. See Normal Quantile Plot.
Outlier Box Plot
Shows the distribution and helps you identify possible outliers. See Outlier Box Plot.
Quantile Box Plot
Shows specific quantiles from the Quantiles report. See Quantile Box Plot.
Stem and Leaf
See Stem and Leaf.
CDF Plot
Creates a plot of the empirical cumulative distribution function. See CDF Plot.
Test Mean
Perform a one-sample test for the mean. See Test Mean.
Test Std Dev
Perform a one-sample test for the standard deviation. See Test Std Dev.
Test Equivalence
Assesses whether a population mean is equivalent to a hypothesized value. See Test Equivalence.
Confidence Interval
Choose confidence intervals for the mean and standard deviation. See Confidence Intervals.
Prediction Interval
Choose prediction intervals for a single observation, or for the mean and standard deviation of the next randomly selected sample. See Prediction Intervals.
Tolerance Interval
Computes an interval to contain at least a specified proportion of the population. See Tolerance Intervals.
Process Capability
Measures the conformance of a process to given specification limits. See Process Capability.
Continuous Fit
Fits distributions to continuous variables. See Fit Distributions.
Discrete Fit
(Available when all data values are integers.) Fits distributions to discrete variables. See Fit Distributions.
Save
Saves information about continuous or categorical variables. See Prediction Intervals.
Remove
Permanently removes the variable and all its reports from the Distribution report.
