Predictive and Specialized Modeling > Predictor Screening > Predictor Screening Platform Options
Publication date: 09/28/2021
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
