Publication date: 09/28/2021
The PValues Data Table
If the PValues Tables on Launch option is selected in the launch window, a PValues data table is created when the Response Screening platform is launched. This data table contains the same information as the Result table that is in the Response Screening report. The PValues data table also contains the additional, model specific columns:
YMean
The mean of Y.
SSE
Appears when Y is continuous. The sum of squares for error.
DFE
Appears when Y is continuous. The degrees of freedom for error.
MSE
Appears when Y is continuous. The mean squared error.
F Ratio
Appears when Y is continuous. The F Ratio for the analysis of variance or regression test.
Intercept
Appears when Y and X are both continuous. The intercept of the regression model relating the corresponding pair of Y and X variables.
Slope
Appears when Y and X are both continuous. The slope of the regression model relating the corresponding pair of Y and X variables.
DF
Appears when Y and X are both categorical. The degrees of freedom for the ChiSquare test.
LR Chisq
Appears when Y and X are both categorical. The value of the Likelihood Ratio ChiSquare statistic.
Robust Elapsed Time
(Appears only when Robust is specified in the launch window.) Computing time, in seconds, required to create the Robust report.
PValues Data Table Scripts
Relevant scripts are saved to the PValues data table. All but one of these reproduce plots provided in the report. When you select rows in the PValues table, the Fit Selected script produces the appropriate Fit Y by X analyses.
