You can add functions to a formula. All of these functions are available in the Functions list of the Formula Editor. This chapter gives a description of functions in the Formula Editor.
More information about functions is available in the following resources:
• The Scripting Index describes all functions and their arguments, demonstrates how the functions work, and links to online Help. In JMP, select Help > Scripting Index to view this interactive resource.
• The JSL Syntax Reference also provides the arguments for JMP functions, not just those available in the Formula Editor. In JMP, select Help > JMP Help and find JSL Syntax Reference in the left column.
Figure A.1 Functions in the Formula Editor
For instructions on how to create a formula that contains a function, see Build Formulas.
