A regular expression is a specification of a pattern frequently used to clean up or extract pieces of data. You can search for a pattern and replace it with a different string or extract specific parts of the string. Define the pattern in the Regex() or Regex Match() function.
• Regex
• Special Characters in Regular Expressions
• Escaped Characters in Regular Expressions
• Greedy and Reluctant Regular Expressions
