Design of Experiments Guide > Sample Size Explorers > Reliability Demonstration Calculators
Publication date: 09/28/2021
Use the Reliability Demonstration calculators to test a specified number of units for a specified period of time. If fewer than k units fail, the demonstration passes, and you can conclude that the product reliability meets or exceeds a reliability standard.
For reliability demonstrations, select DOE > Sample Size Explorers > Reliability:
Parametric Reliability Demonstration
Nonparametric Reliability Demonstration
