The Repairable Systems Simulation Results red triangle menu contains the following options:
Point Estimation of Component Availability
For each block shape in the system diagram, this option shows the following reports:
– Point Estimation of Availability Profiler
– Available Time Distribution
– Availability Distribution
– Point Estimation of Unplanned Outage Profiler
– Unplanned Outage Time Distribution
– Unplanned Outage Distribution
System Availability by Period
Shows a graph that enables you to examine the average system availability during specified time periods. Use the By Time panel to define the time period as an interval of time. Use the By Event panel to define the time period as a specified number of occurrences of one event. When you click Go, the report shows a bar chart of the average system availability during each period.
Box Plot of System Total Downtime by Component
Shows a box plot of the total time the system was in the Down or Off states caused by individual components. The components are ordered by contribution from the most outage time to the least outage time, similar to a Pareto chart.
Box Plot of System Unplanned Total Outage Time by Component
Shows a box plot of total time the system was in the Down state caused by individual components. The components are ordered by contribution from the most outage time to the least outage time, similar to a Pareto chart.
See Redo Menus in Reports and Save Script Menus in Reports in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
