Right-click a column in a table to see the following options:
Delete
Deletes the selected column.
Use as Grouping column
Changes the analysis column to a grouping column.
Use as Analysis column
Changes the grouping column to an analysis column.
Change Item Label
(Appears only for separate or nested columns.) Enter a new label.
Combine Tables (Columns by Categories)
(Appears only for separate or nested columns.) Combines separate or nested columns. See Example of Combining Columns into a Single Table.
Nest Grouping Columns
Nests grouping columns vertically or horizontally.
Separate Tables
(Appears only for combined tables.) Creates a separate table for each column.
Remove Column Label
Removes the column name from the column table.
Restore Column Label
Restores a hidden column name to the column table.
Order By Count
Orders the levels of a grouping column by the count of each level, from most to least. This option can also be used to override the setting of the Order by count of grouping columns option for a particular grouping column.
